ㄚ諾 工 400cc級騎士 (大型重型)
註冊時間: 2004-08-13 文章: 522 居住地: 台灣
發表於: 星期一 五月 09, 2011 6:06 pm 文章主題: |
| 真是棒 寫到: |
請勿以訛傳訛
沒發動還有殘餘煞車力道
我經常滑行進地下室停車場
要很用力壓就是 |
我是02年R1200C,我試過沒開電門滑入地下室
,剎車力道跟有發動時差不多??? |
真是棒 火雲邪神 笑 傲 車 壇
註冊時間: 2008-12-13 文章: 8522 居住地: 台灣西西里
發表於: 星期二 五月 10, 2011 1:14 am 文章主題: |
BMW好像每種車型前後煞車分配比例力道都不同???我是以個人的經驗來說在沒發動的情況下還是有煞車,至於ABS故障後煞車的情況我就沒經驗.但也可能是我工作常搬重物的關係,分不出來煞車力道的不同  |
qiyi1982
註冊時間: 2011-05-09 文章: 45
發表於: 星期二 五月 10, 2011 1:37 pm 文章主題: |
昨天我嘗試了一下,我的02年1150RT,在滅火後剎車,第一下非常恐怖,像捏空了一樣,緊接著就OK了,明顯感覺到了有剎車的力度,雖然沒有像EVO那麼強勁的力度,但是應該可以穩定的將車慢下來,所以建議朋友們一旦有滅火的情況,別驚慌,要多次捏剎車才能將車速降下來。 _________________ 北京的RT騎手 |
註冊時間: 2007-11-15 文章: 11743
發表於: 星期日 一月 29, 2012 3:00 pm 文章主題: |
如果出現 17433碼
17433 Pressure in rear wheel circuit to low.(The fault is not present now)
這是主要訊息,國外說partial integral abs ~完蛋了
http://www.adventuremx.co.za/bmw%20diagnostics.htm
17433 Pressure in rear wheel cylinder to low. R1150RT Refer to fault code 17163 for details on symptoms. It would be best to have your nearest BMW agent confirm your fault code. Replace complete ABS unit, which will be very costly. Clear fault codes
國外也在幹幹叫
http://www.bmbikes.org.uk/Forum/viewtopic.php?f=14&t=10775
Re: RT 1150 no servo brake failure light flashing
by torvil » Tue Apr 06, 2010 12:57 pm
OK...
I have had the disgnoses which is identical to "belledog"s symtoms on the forum titled another abs problem, in that I had similar flashing light progression into constant 4hz with only residual braking.
Took it to dealer who diagnosed the same, abs module faulty due to one pump over pressuring.
They asked BMW for goodwill assistance, who declined due to the bike being too old.
I have written to BMW who have acknowledged by automation my e-mail. I have asked for;
1. should the bikes be recalled to due unexpected brake failure?
2. would BMW assist me with any goodwill by replacing the part free of charge, I am prepared to cover the labour myself, as I would imagine that the manufacturer would be keen to carry out research with the faulty part.
I have not had a response from them so far.
I dont know how the system works with the vehicle inspectorate new vehicles are tested for type approval, but I would imagine that manufacturers would struggle to get vehicles passed if a braking system suddenly reduced in effieciency to 30% due to a malfunction with a the abs unit whilst being tested?
Taking on a big corporation is very intimidating, but look how Toyota are paying the price now.
My dilemma now is whether to go for abs removal, or replace or repair the unit.
There are companies which offer recon abs units for cars but none advertise for bikes. Are all abs units similar in operation, or are the motorcycle unit which incorporate servo pumps unique?
Can anyone recommend a an agent who does this.
Additionally, I have spoken to the manufacturer who supplied these units "FTE automotive" who no longer manufacture these units and do not offer a recoditioning service. _________________ 人族當有超越一切的東西 若有悖 法律改 民族讓 國家低頭 |
nomarski
註冊時間: 2005-09-13 文章: 1263
發表於: 星期日 一月 29, 2012 8:34 pm 文章主題: |
| yen_kofu 寫到: |
| "FTE automotive" who no longer manufacture these units and do not offer a recoditioning service. |
所以說以後若不幸壞了,就算想花錢換也沒得換!?
哇勒~~~  |
bmwjhj
註冊時間: 2009-11-04 文章: 42
發表於: 星期三 二月 01, 2012 10:40 am 文章主題: |
| 我的車是02年的水平對臥,裝了一組"電壓表"請問 是否對於電瓶效能有幫助? |
發表於: 星期五 二月 17, 2012 9:50 am 文章主題: |
| nomarski 寫到: |
哇勒~~~  |
有得換!
一定有在賣 !
FTE怕被告,先躲起來再說,讓你找不到
| bmwjhj 寫到: |
是的 !
5-Function Digital Volt Meter Price: $34.99
http://www.ascycles.com/detail.aspx?ID=47554
電壓起伏對電子零件很傷,大電流的衝擊對Partially integral brakes也很傷(國外有說),衝擊能量看不見,但是可以想像及描述,例如在海底行走的Tsunami能量看不見,其上行走的船也不知道下面有Tsunami,直到Tsunami能量到岸邊才發作/轉換成"浪"
未接上電瓶,全波整流充電器~電壓起伏的"浪"用示波器看得見(三用電錶的AC檔測得到),但是接到電瓶就看不見這個"浪",看見的是直流電電壓(用三用電錶測~玩玩看~這是習題),因為這個"浪"被電瓶吸收了,"浪"哪企了呢?
最近找東西這事很熱門
換一組新的Partially integral brakes之後,每次煞車都攬趴撞油箱,之前習慣拚命煞 !!! _________________ 人族當有超越一切的東西 若有悖 法律改 民族讓 國家低頭 |
jsba jsba 腳踏車騎士 (無照駕駛)
註冊時間: 2012-02-14 文章: 15
發表於: 星期五 二月 17, 2012 3:37 pm 文章主題: |
| bmwjhj 寫到: |
電壓表只能讓你看到電池電壓狀況,對於電瓶效能無任何幫助哦!! |
阿莫
註冊時間: 2008-07-01 文章: 475
發表於: 星期四 三月 15, 2012 8:53 pm 文章主題: |
| 021150RT第一次起動外出ABS燈快閃、故障燈恆亮有煞車力道(較弱),之後往加油站加油後再次啟動,上述情形變正常。電池已經3年了,是否代表要換新電池 |
發表於: 星期四 三月 15, 2012 10:01 pm 文章主題: |
電池先換了吧 ! _________________ 人族當有超越一切的東西 若有悖 法律改 民族讓 國家低頭 |
天樑星
註冊時間: 2011-09-13 文章: 463
發表於: 星期二 三月 20, 2012 2:25 pm 文章主題: |
大家多在討論電池的事
個人有一個經驗可參考
就是電子節氣閥如果故障也會如樓主依樣
不是壞掉是卡住
我花很久時間才查出來
試試看 |
jerelychou 歐爸陛下 重車玩家級
註冊時間: 2011-12-02 文章: 1512 居住地: Taipei
發表於: 星期一 三月 26, 2012 10:43 pm 文章主題: |
所有的BMW機車都會嗎? _________________ 騎小鳥的霹靂貓~ |
發表於: 星期三 四月 04, 2012 8:02 am 文章主題: |
| 天樑星 寫到: |
大家多在討論電池的事
個人有一個經驗可參考
就是電子節氣閥如果故障也會如樓主依樣
不是壞掉是卡住
我花很久時間才查出來
試試看 |
電子節氣閥是甚麼???
有圖給大家看也可以 ! _________________ 人族當有超越一切的東西 若有悖 法律改 民族讓 國家低頭 |
Phang 聯邦人 - 敝姓彭 神 的 領 域
註冊時間: 2006-08-17 文章: 6193 居住地: 南洋
發表於: 星期三 四月 04, 2012 8:33 am 文章主題: |
| yen_kofu 寫到: |
電子節氣閥是甚麼???
有圖給大家看也可以 ! |
伺服馬達控制,沒有用油門鋼索的
