新R1300GS國外發生火燒車啟動繼電器引起
文章: 11743
發表發表於: 星期五 二月 09, 2024 1:17 am    文章主題: 新R1300GS國外發生火燒車啟動繼電器引起 引言回覆
老車R1150R用料實在反而安全, 新車新毛病R1300GS燒起來啦~有圖有真相 !
BMW R 1300 GS: Dicey situation! The starter relay problem
https://youtu.be/p9ihAkP2_k4?si=f_q3pTbbLp-3Pd0K
Starter motor relay recall… | ::. UKGSer .::
Nov 22, 2023
https://www.ukgser.com/community/threads/starter-motor-relay-recall%E2%80%A6.376818/
UKGSer論壇作者RT_slippers說Jan 24, 2024
The new BMW R 1300 GS experiences strange and dangerous technical malfunctions, including fires. Trigger: the starter relay. BMW measures: delivery blocks and a “service campaign” – i.e. the first recall for the new R 1300 GS.
BMW delivered the new R 1300 GS to dealers from the beginning of November 2023, but vehicle handovers to customers were initially held back in November (delivery block) - and at the end of November there was a spectacular incident at our colleagues from 1000PS in Austria.
Smoking BMW R 1300 GS with 1000 HP
被譏笑的~冒煙的1000 匹馬力 BMW R 1300 GS
壓縮比 13.3:1
最高馬力 145PS(107kW) @ 7,750rpm
最大扭力 149Nm @ 6,500rpm
The test vehicle loaded into the transporter, the BMW R 1300 GS, suddenly turned the starter on its own in November 2023, as a result of which heat and fire developed with corresponding smoke and burn marks on the motorcycle. By quickly disconnecting the battery, something worse could probably have been prevented.
2023 年 11 月,裝載到運輸車上的測試車輛 BMW R 1300 GS 突然自行啟動起動器,導致摩托車發熱並起火,並在摩托車上產生相應的煙霧和燒痕。 透過快速斷開電池,可能可以避免更糟糕的情況發生。
First statement from BMW in November 2023
BMW's first statement at the time: "On November 9, 2023, as part of a service campaign (BMW R 1300 GS, check starter relay and replace if necessary), a temporary delivery ban was imposed for the affected vehicles, which was linked to the implementation of this technical campaign The reason for this action is isolated damage to the plastic coating of the starter relay during initial installation. This can cause moisture to enter and lead to failure of the starter relay."
寶馬當時的第一份聲明:「2023年11月9日,作為服務活動的一部分(BMW R 1300 GS,檢查起動機繼電器並在必要時更換),對受影響的車輛實施了臨時交付禁令,這與實施這項技術活動的原因是在初始安裝過程中啟動繼電器的塑膠塗層被隔離損壞。這可能導致濕氣進入並導致啟動繼電器故障。
Problems with the starter relay seemed to be solved early on
According to BMW, 854 vehicles in Germany and 85 vehicles in Austria were affected at the time. “Since November 6, 2023, only vehicles without this error pattern have been delivered in series,” said BMW in a statement at the end of November. And further: "At the time of the delivery ban, all affected vehicles were still before handover or before registration, with the exception of a few demonstration vehicles, and will be fitted with new starter relays at short notice that do not show any damage. The R 1300 given to 1000PS for test purposes GS was one of the affected vehicles that had not yet been converted to a new starter relay."
New statement from BMW in January 2024
But apparently BMW still doesn't have the problems with the starter relay on the R 1300 GS under control at the end of January 2024. There were further fire-threatening incidents involving stationary and even moving motorcycles. The only effective countermeasure: disconnect the battery as quickly as possible. Latest statement from BMW: "For vehicles before delivery, the starter relays will be replaced before handover to the customer. For vehicles that have already been delivered, customers will be informed of the matter and asked to carry out the service campaign. Since January 16, 2024, only Vehicles delivered without this error pattern."
Another delivery ban and first recall campaign for the BMW R 1300 GS
In plain language this means: There is another delivery block and a recall campaign - this is the first for the new R 1300 GS. MOTORRAD inquiry regarding scope, duration and technical details is ongoing.
johnb2897
註冊時間: 2011-12-19
文章: 847
發表發表於: 星期五 二月 09, 2024 7:09 pm    文章主題: 引言回覆
個案吧
需要REDLINE MOTUL 和SENA等產品
賴johnb2897
文章: 11743
發表發表於: 星期六 二月 10, 2024 1:51 am    文章主題: 引言回覆
johnb2897 寫到:
個案吧
No !
你嘛看看英文
「根據說明,應該是繼電器的線圈絕緣漆品質極差,造成繼電器的「漆包線」線圈「層間短路」,
此外,摩托車靜態中也會起火?摩托車電源鑰匙沒啟動也會起火?那就是摩托車的線路設計的問題了,是吧?這也就是犯了低級錯誤,荒唐啊!」
Nov 22, 2023
No !
你嘛看看留言
YouTube 留言在「BMW R 1300 GS: Dicey situation! The starter relay problem」首頁的連結
YouTube 留言如下
「@TheStammeringBiker
This happened to mine, borderline caught fire when washing it, been with the dealer for almost 2 weeks now…」,我的就遇到這種情況,洗車的時候邊緣冒火了,和經銷商聯絡了已經快兩週了
No !
你嘛看看我的留言~圖文並茂~都冒火啦
johnb2897
註冊時間: 2011-12-19
文章: 847
發表發表於: 星期日 二月 11, 2024 7:50 am    文章主題: 引言回覆
台灣都說是個案 冏
賴johnb2897
文章: 11743
發表發表於: 星期日 二月 11, 2024 8:08 am    文章主題: 引言回覆
johnb2897 寫到:
台灣都說是個案 冏
個不個案? 自己選擇相信或不相信。
我只提供訊息,我只看國外訊息,在台灣就要自求多福,小心點就是了。
就像傻B只選擇民進黨,傻唄,活該去死。
johnb2897
註冊時間: 2011-12-19
文章: 847
發表發表於: 星期二 二月 13, 2024 7:01 am    文章主題: 引言回覆
很多台灣的個案 到大陸 大量車主抗議打官司後 就變招回了
賴johnb2897
文章: 11743
發表發表於: 星期三 二月 14, 2024 7:02 am    文章主題: 引言回覆
johnb2897 寫到:
暫時禁止送貨令
johnb2897
註冊時間: 2011-12-19
文章: 847
發表發表於: 星期三 二月 14, 2024 6:43 pm    文章主題: 引言回覆
反正我朋友訂車 說要六月才會到 我們來看何時要交車
賴johnb2897
文章: 66105
發表發表於: 星期四 二月 15, 2024 10:12 am    文章主題: 引言回覆
johnb2897 寫到:
台灣都說是個案 冏
不說是個案的話 叫車商怎麼賣? hehe
https://motocity.com.tw/gp3/viewtopic.php?t=201588
文章: 11743
發表發表於: 星期四 二月 15, 2024 10:30 am    文章主題: 引言回覆
人家有說~
2024 BMW R1300GS 全新世代水鳥火熱預購中
kyocott
台南阿智
kyocott
註冊時間: 2006-08-03
文章: 2528
發表發表於: 星期三 二月 21, 2024 11:08 am    文章主題: 引言回覆
看來明年才有機會進來了~~
bmw一直降低品質~~還不是因為愛中國的關係~~不然早期零件都是mit~~還是台灣製的可靠~
BMW HP2 ENDURO
海絲瓜 fe250 有牌
DT125
文章: 11743
發表發表於: 星期六 二月 24, 2024 4:11 am    文章主題: 引言回覆
在youtube的視頻作者已經說啦
我們對 BMW R 1300 GS 以及起動機繼電器持續存在的問題進行了認真的審視,該問題導致了嚴重的安全問題。 2023 年 11 月因過熱和火災損壞事件引發召回後,問題最初似乎得到了解決。 然而,儘管寶馬做出了努力並採取了安全措施,事故仍然發生,即使是在行駛中的摩托車上
We take a critical look at the BMW R 1300 GS and the ongoing problem with the starter relay, which is causing serious safety concerns. After the recall in November 2023, triggered by cases of overheating and fire damage, the problem initially seemed to be solved. However, despite BMW's efforts and safety measures, incidents continued to occur, even on moving motorcycles.
johnb2897
註冊時間: 2011-12-19
文章: 847
發表發表於: 星期日 二月 25, 2024 7:58 am    文章主題: 引言回覆
訂金多久 沒收到車 可以拿回阿
賴johnb2897
文章: 11743
發表發表於: 星期四 五月 09, 2024 12:28 am    文章主題: 引言回覆
高雄國10 BMW火燒車 超狂阿伯淡定救援
https://youtube.com/shorts/MbTRA8XH-Wc?si=QIFvMEpgv7Jid1wL
johnb2897
註冊時間: 2011-12-19
文章: 847
發表發表於: 星期六 六月 22, 2024 4:33 pm    文章主題: 引言回覆
我朋友已經交車1300gs在台灣騎了 等著看發展
賴johnb2897
