新人報到之daytona 675小疑問
yoyo89833 寫到:
溫馨提醒一下daytona 675的車主們, 記得每次出遊前檢查一下機油量....675會吃不少機油, 尤其是愛拉轉的車主, 但散步組也要注意 hoho
如果是06-08年的daytona車主, 記得看油量棒是不是舊款的, 是的話機油就得加到過量的那格, 這是當初凱旋又一個設計疏失....
上面那隻是09年之後的, 下面是06-08年的, 一比較就知道為什麼06-08年的要加到頂端了!
前輩的意思是說 我們06舊款的 必須加到新款綠色指標線那嗎?
前輩在國外的話可以委託買零件嗎...(汗),但服務費是少不了一定給的! Smile
loveforwhat 寫到:
這是論壇的原文, 寫的人是個凱旋的技師, 有需要翻譯的話我再翻...
I know we all discussed this deeply back in the Spring but I had a chance to photograph the old and new dipstick side by side today and measure them. Also since then I've gotten to read the official Triumph bulletin detailing the release of the updated dipstick. So in order to put everything in one place for easy reference I'm creating this new thread. So here goes.
For those that are uninformed on this topic Triumph starting with the 09 Daytonas shortened the oil dipstick and therefore increasing the oil volume of the bike. There was a great deal of conjecture and assumptions made surrounding this change with many people believing that Triumph had altered the oil pan or internals of the bike in order to increase the oil capacity. The truth is far simpler. There were no internal changes and the oil pan is the same they simply shortened the oil dipstick in order to increase the oil volume. Triumph along with this change released bulletin detailing all this and simply stated that the oil dipstick is retrofittable and the oil level can be increased on all the older 675s but that there was no recommendation to do so.
I have been carefully following any mention of engine failures that I can find on the internet and have personally come to the conclusion that this should be made a mandatory change. It's not that it will affect 99% of the riders but for that 1% that rides track days does wheelies and in general pushes their bike to the limit it reduces the chances they are taking on incurring some form of engine damage from oil starvation. Even of those 1% there is no guarantee that doing any of the things mentioned could cause any damage at all but there is some chance so for that alone I think it's good protection at very little cost to the rider.
Of note Triumph implements production changes at any time of production and notes the changeover by vin number. So just because your bike is an '09 does not mean you have received the change. You will have to visually inspect the dip stick to be sure of what one your bike has.
The measurement differences are as follows as measured from the top sealing surface of the dip stick down to the level marks.
_____________Overall length
Old dip stick____90mm(3.54")
New dip stick___77mm(3.03")
Oil level marks____Full mark________Low mark
Old dip stick_______59mm(2.32")____78mm(3.07")
New dip stick______43mm(1.69")____62mm(2.44")
As you can see from the measurements and the image the high mark on the old dipstick is actually within a few mm of the low level of the old dip stick and the top of the hatch marks on the old dipstick is actually very close to the full mark on the new dip stick. I have been running my own bike at the top of the hatch marks and on street or track I have had no issues with this (as to be expected as per Triumphs own information). It is our own shop policy to either replace the old dip stick with the new one or to fill the bike to the fuller level on the old dip stick. We feel this is a service to our customers despite the information from Triumph saying it is unnecessary.
所以總結是: 是的, 加到新款綠色指標線那裡
您需要甚麼零件? 服務費就免啦...車友間互相幫忙 Smile 零件和郵費就好了
感謝~~
所以如果換機油時有更換油濾,機油總添加量大約3.7或3.8L嗎?
skylooker 寫到:
感謝~~
我問過主辦英國凱旋Daytona 675賽事的車行, 在英格蘭沒有別的車行比他們更了解Daytona 675了.... 他們是說大約3.8L, 但實際還是以機油量表為準!
yoyo89833 寫到:
06年的我含油心才3罐耶 what
那sprint st 1050要加多少呢~~我目前是加3.4L而已~會不會太少阿
柏威 寫到:
06年的我含油心才3罐耶 what
已實際車上的機油量劑高度為準
yoyo89833 在 星期日 四月 28, 2013 5:07 pm 作了第 1 次修改
蔡景揚 寫到:
sprint不清楚呢.....
