我的STX放手車身會偏右邊是正常的嗎???
前車主說是因為V缸跟傳動軸出力的關西才會偏右邊
真的是這樣嗎?好怕買到事故車= ="
因為之前都是騎直4的引擎第一次接觸休旅車
請問各位騎STX的前輩是否真的是會偏右邊還是我真的買到........= ="
我是沒什麼特別的感覺會右偏
會!! 會慢慢 往右偏
左岸 寫到:
會!! 會慢慢 往右偏
感謝左岸大大的解答 hoho
害我一直擔心會不會去買到事故車
原來是正常的
逛了一下國外的網站發現他們也有同樣的問題.不過好像有解決的半法.
08年好像有修改前輪組裝方式.
ST1300-Bike Pulls to the Right
by SoloTotoCoyote 04-28-2008, 12:01 PM
Comments (4)
Ok. So I did some homework in regards to some of the complaints that the ST is pulling to the right. Unofficially, it looks like it may indeed be a set up issue. If this is the cause, then it means that the problem is dealer related and not Ma Honda』s fault. When the ST』s arrive at the dealer in the crate, the front wheel is not installed. Looking at the past two years set up manuals for the ST and cross checking with the service manual. Honda made a small change to the set up instructions in regards to the front wheel. Here』s the install directions for the 2008 ST1300:
(Note: Axle pinch bolts are finger loose at this point)
1. Tighten the left axle pinch bolts to 22 N-m (2.2 kgf-m, 16 lbf-ft)
Note: Indication of 「Left」 is if you were sitting on bike
2. Tighten Axle Bolt to 79 N-m (8.1 kgf-m, 58 lbf-ft)
3. Tighten the right axle pinch bolts to 22 N-m (2.2 kgf-m, 16 lbf-ft)
4. Now loosen the left axle pinch bolts
5. Note: During the assembly process, this is where you would be installing the brake calipers.
6. Set the bike down where the bike's weight is on the wheels. Lock the front brake and push the suspension up and down several times.
7. Tighten the left axle pinch bolts to 22 N-m (2.2 kgf-m, 16 lbf-ft)
You』ll notice that they have you loosen and retighten the left axle bolts before and after you』ve tightened the axle. I think this may be where the front end pulling is coming from. With the left axle pinch bolts tightened down, tightening the axle bolt would pull the two forks together……or more precisely, it』s pulling the left fork towards the right. Once you』ve tightened down the right axle pinch bolts, loosening the left axle pinch bolts lets the assembly center itself.
I hope I explained this in a way that makes sense.
So if your ST is pulling to the right, and it's definitely not tire related, give this a try. Loosen everything up and tighten it in this order. Make sure the front tire has no weight on it when you do it, too. Put the bike on the center stand and have someone push down on the bike while you work. If you've had your bike less than 30 days or are approaching the 600 mile service, take it back to the dealer. Tell them it's pulling, (don't say it happens when you take your hands off) and ask them to loosen and recheck the front wheel. Mention that the set-up manual is specific about how the front wheel is torqued and if not done correctly it will pull.
I also looked to see if there was anything with the back wheel that could cause it. The wheel just bolts on with no adjustment possible from what I can tell.
It』s interesting to note how the set-up directions for the previous year differed. For the 2007, they indicated that the axle bolt be torqued first, then the right side pinch bolts, the brake calipers would be installed and then the left side would be torqued.
Hope this helps.
用Google翻譯~~~
將英文翻譯為中文(繁體)顯示拼音
ST1300 -自行車拉至右
由SoloTotoCoyote 2008年4月28日,下午12:01
評論(4)
確定。所以我做了一些功課在某些方面的投訴,ST是拉向右邊。本月24日,它看起來像它可能確實是成立的問題。如果這是原因,那麼這意味著經銷商的相關問題,而不是馬本田的錯。當 ST的到達經銷商在板條箱,前輪沒有安裝。回顧過去兩年成立的ST手冊和交叉檢查與服務手冊。本田做了一個小改變,就指示成立的前輪。下面是安裝方向2008年ST1300:
(註:軸手指捏螺栓鬆動在這一點上)
1。左軸捏擰緊螺栓到22牛頓米(2.2公斤力米,16磅英尺)
註:標誌的「左」的是,如果你是坐在自行車
2。螺栓擰緊軸至79牛頓米(8.1公斤力米,58磅英尺)
3。右軸捏擰緊螺栓到22牛頓米(2.2公斤力米,16磅英尺)
4。現在鬆開捏左軸螺栓
5。註:在裝配過程中,這是您將要安裝的制動卡鉗。
6。設置在自行車的自行車下來的體重是在車輪。鎖定前制動和懸掛起來,推動了幾次。
7。左軸捏擰緊螺栓到22牛頓米(2.2公斤力米,16磅英尺)
你會發現,他們有你放鬆並重新擰緊螺栓軸左之前和之後您已經收緊了車軸。我認為這可能是在前端的是來自拉。隨著左軸夾螺栓收緊了,收緊軸螺栓將兩叉拉在一起... ...或更確切地說,它是拉動萊夫特福克朝著正確的。一旦你已經收緊了正確的軸夾螺栓鬆動捏左軸螺栓讓大會中心。
我希望我解釋這在某種程度上是有道理的。
所以,如果你拉的ST是正確的,這絕對不是輪胎有關,嘗試一下這個。鬆開一切行動和加強它在這一秩序。確保前輪胎沒有重量,它當你做了這一點。把自行車上的立場,該中心已經有人在自行車上推下來,而你的工作。如果你有你的自行車不超過 30天或接近六英里服務,是否可以返回經銷商。告訴他們這是拉,(不要說發生在你把你的手關閉),並要求他們放鬆和重新檢查前輪。提到,設置手冊具體如何扭轉前輪是正確的,如果沒有這樣做會拉。
我也期待,看看是否有什麼與後輪,可能導致它。該輪只螺栓沒有調整可能從我可以告訴。
很有趣地注意到如何設定方向上一年有所不同。對於 2007年,他們表示,扭轉軸螺栓是第一,然後在右邊捏螺栓,制動鉗,然後將安裝在左側將扭轉。
希望這會有所幫助。
國外網站\
http://www.st-owners.com/forums/showthread.php?t=40003
2008年為經銷商設置
http://stwiki.notonthe.net/twiki/bin/viewfile/ST13/SetupInstructions?rev=1;filename=2008-setup.pdf
