[youtube:8703130fde]http://www.youtube.com/watch?v=jbbsDds1tbU&feature=channel&list=UL[/youtube:8703130fde]
以下是所有的回應或評論
It's simply poetry
RoyalEnfieldfahrer 1 月 以前
this is the firist motorcycle from all time????
ninjeacatalin 7 個月以前
If there was a way to keep the crap out of the cylinders, to put in spark ignition and perhaps a clutch and then a sealed chain drive.....
Unless you added extra shielding and vented the exhaust out the back of the cylinders to keep the space filled with clean gases instead of dust and crap...
callmeshane303 7 個月以前
Wow,just wow.One really has to admire ingenuity and engineering of old motorcycles.
Wendy3634745673 10 個月以前
I love the sound !
6TauG6E6NiX6 10 個月以前
really cool motorcycle!
but how to stop that thing? It look like it doesnt have a clutch or something else^^
(sorry for my bad english)
Matze941 11 個月以前
Matze941 11 個月以前
du stoppst, indem du bremst und folglich den motor damit abwürgst ^^ und beim starten musst du wieder anschieben ^^ jedenfalls so weit ich das mitbekommen hab...ich seh zumindest auch keine kupplung
soopawhoops 回覆對像: Matze94111 個月以前
AMAZING! I love how the owner still rides it, the way it was meant to be!
PhotosByHamza 1 年 以前
105 years old,it runs, and it is amazing!. Connecting the pistons straight to the rear axel is killing three birds with one stone,no driveshaft,no transmission,no extra crankshaft.I wonder what kind of gas milage it gets.
inkydoug 1 年 以前 3
wow this is amazing.
Mesyri1000 1 年 以前
Anda mais que a minha bicicleta e que a moto do meu vizinho !
carlotavares23 1 年 以前
Nooit gedacht dat ik deze motor nog ooit zou zien of horen. Buitengewoon..........
pijnscheut 1 年 以前
unbelievable! let's see how a modern crap-bike from 2010 is working in more than 110 years :P
purpleGoAhead 1 年 以前
That was so awesome! I wish you had a helmet cam segment in the video, going a higher speed.
stopglobalswarming 1 年 以前
Beautiful !
Excellent work !!!
lilaclancer 1 年 以前
GREAT video! I saw one of these in the Guggenheim Museum "The Art Of The Motorcycle" display in Las Vegas, Nevada a couple of years ago. I never thought I'd see one run.! Thank you so much .. What a treasure!!
That thing would probably blow the doors off anything on the road in 1896!!
JGMagoo 1 年 以前
i like it very much.......
Britbike20 2 年以前
Incredible! I cant belive you have a wokring model! How hard was it to restore?
VinnyMartello 2 年以前
Totally cool. Sounds a little like a friends "hit and miss" but look at it go. How much fun one could have had back in 1896. I know that here in the states, speed limits had been instituted to keep automobiles from speeding, and scaring horses. How fast would this go?
NcalBiker 2 年以前 5
NcalBiker 2 年以前 5
28-31 mph
ShamilBasayev 回覆對像: NcalBiker2 年以前
NcalBiker 2 年以前 5
28-31 mph
Sorry for taking so long. Thank you. Amazing how technology advances, and yet it's things such as this that make you wonder what it must have been like to see it chugging down the street in it's day. Fantastic. Thanks again.
NcalBiker 回覆對像: ShamilBasayev2 年以前
about 60,000 pounds..
ThePoster100 2 年以前
another exists in the rex /peter judd collection in uk.
1956triumph 2 年以前
Haette ich gerne mal beim "anmachen" gehört..
Hört sich an wie ein alter Trecker mit Standgas
Nitro19922 2 年以前 6
Das ist Genial!!
Ich habe mir beim ansehen der Daten dieses legendären Motorrades, immer schon die Frage gestellt, wie es sich denn im Betrieb anhört.
Danke!!
ILoveKaters17 2 年以前 6
thats cool I want one then ill take it to the highway.
ilove1994 3 年以前 12
That IS the coolest motorcycle!
injunscout 3 年以前 7
OK guys, here is some tech talk.
Patent of 20 January 1894, 2 Cylinder four-stroke engine, 1488cc, Bore and stroke: 90 x 117mm, Ax. 2.5HP at 240rpm. Weight ax. 60kg and a maximum speed of ax. 50km/h. The Motorbike features a water-cooled ( the water is carried in the rear mudguard ) engine .The rear wheel acts as a cranckshaft and is driven by pistons similar to those in a locomotive.
It has a surface carburetor and hot tube ignition.
This really is the first production motorcycle ever !
vtwinohc 3 年以前 31
vtwinohc 3 年以前 31
That was very knowledgeable... thanks.....
nnoval01rd 回覆對像: vtwinohc10 個月以前
the machine look like a steam bike .kha...ching...kha...ching... is it ?
rusnanerces 3 年以前 7
rusnanerces 3 年以前 7
That is because it is heavily based on steam design. Instead of pressurized steam moving the pistons in the cylinder, it used gasoline! The rear wheel is also the flywheel and the pistons are attached to it like on a steam locomotive.
CrazyAlvis 回覆對像: rusnanerces2 年以前 7
dit is stukken beter dan een ketting of cardan.Hier is vast geen 2e van,schitterend!
terommetje 3 年以前 6
Awesome! Is this an original or a replica?
moisiemo 3 年以前 4
moisiemo 3 年以前 4
Original. Probably the only working example of the first production motorcycle.
douro20 回覆對像: moisiemo5 個月以前
以下是所有的回應或評論
It's simply poetry
I love the sound !
Matze941 11 個月以前
Matze941 11 個月以前
inkydoug 1 年 以前 3
Mesyri1000 1 年 以前
pijnscheut 1 年 以前
Beautiful !
Excellent work !!!
lilaclancer 1 年 以前
JGMagoo 1 年 以前
Britbike20 2 年以前
VinnyMartello 2 年以前
NcalBiker 2 年以前 5
NcalBiker 2 年以前 5
28-31 mph
NcalBiker 2 年以前 5
28-31 mph
ThePoster100 2 年以前
1956triumph 2 年以前
Nitro19922 2 年以前 6
Das ist Genial!!
Danke!!
ilove1994 3 年以前 12
injunscout 3 年以前 7
vtwinohc 3 年以前 31
vtwinohc 3 年以前 31
rusnanerces 3 年以前 7
rusnanerces 3 年以前 7
terommetje 3 年以前 6
moisiemo 3 年以前 4
moisiemo 3 年以前 4
