最近 G650X Challenge 時速不準 清潔後輪ABS sensor無效後 找到重新設定方法 結果就ok了 與大家分享
1. Remove the seat (the main fuse box is now clearly visible)
2. Remove the ignition key if you haven't already done so (really important!!).
3. Open the main fuse box, and remove the 15A fuse from the slot "Fuse F".
4. On the dash, hold down the "set" button, and re-insert the fuse back to its slot "F".
5. Keep holding down the "set" key while the dash starts to count down from 15 to 1(the bike will not explode).
6. Next the dash is going to toggle between three rear wheel size choices. You can let go of the "set" button.
7. When the dash shows you the preferred rear wheel size press "mode".
8. Done. Now the new wheel circumference is set.
