rs6
星期四 一月 09, 2014 9:01 am
文章主題: BMW is Recalling 50,000+ Bikes Due to Potential Fuel Leaks
北美主要招回車型有
2005-2011 R-models, 2005-2012 K-models, 2010-2011 S1000RR models, and 2006-2010 HP2 models
提供給各位大大參考
詳細內容可參考
http://www.asphaltandrubber.com/recall/bmw-motorrad-fuel-leak-recall/
rs6 在 星期四 一月 09, 2014 9:13 am 作了第 1 次修改
Phang
星期四 一月 09, 2014 9:16 am
我猜應該是這個
我車友的HP2才自已掏腰包換不久,不知道可不可用向米漿要回銀兩
Samhuang1968
星期四 一月 09, 2014 9:34 am
yes ..
" According to BMW, the reason for the recall is the fuel pump flange and auxiliary fuel pump flange may develop cracks and leak, which may result in fires",
燃油幫浦法蘭破裂, 造成漏油, 有引燃的危險, 之前R系列一堆車友討論的沸沸揚揚, 還有DIY自行改善, 都是繞著這個問題, 但是這個Recall 訊息是BMW 北美發出,.不知是否是全球性的召回..
According to the NHTSA, this is a problem that BMW has been aware since at least 2011 because they attempted to remedy the issue by reinforcing the fuel pump flange with a metal collar to prevent future leakage.
文內還提到, BMW顯然了解此一問題的嚴重性, 在2011嘗試使用金屬材質..看看內湖怎麼說...
R45
星期一 一月 13, 2014 1:37 pm
hey Sam...let me know if BMW taiwan will replace them...my ADV
also has cracked flanges
Samhuang1968
星期一 三月 10, 2014 10:27 am
Finally it takes almost two month to react..
