請問RSV4改蠍管+ECU
想請問大家有人給總代理買過全段蠍子管嗎?
今天打電話過去問,是說目前買全段蠍管還會附一顆ECU
不知道他們說的ECU是指RACE ECU 還是單純拿來配全段蠍管的供油的?
因為我問他們是說這顆ECU裡面是空白的,要拿原廠給的條碼打進去才會有東西
而原廠的ECU是不可改的
(裝上RACE ECU 是螢幕上就會有RACE了嗎 what )
http://www.af1racing.com/store/Scripts/prodView.asp?idproduct=8105
Aprilia Accessory "Race" ECU for '09-'14 RSV4 (all models) and '11-'14 Tuono V4. -#896309
When you order this official Aprilia ECU, AF1 Racing selects the newest, and best available RACE map for your V4 . This ECU is "unlocked" and can be updated to newer RACE maps by your dealer (if newer maps become available).
This ECU is pre-programmed with the official Aprilia the RACE map for use with aftermarket full system or slip-on exhausts.
Not USA Emissions/DOT legal. AF1 Racing strongly recommends purchasing this RACE ECU in if you have installed an exhaust system with no catalytic converter or a removable dBkiller. When using exhaust systems without catalytic converter but with the dB-killer installed (such as when riding on circuits with noise restrictions), using the racing ECU is still recommended.
The ECU is loaded with the three maps R, S and T, all of which full power maps. The R map limits torque in the first three gears recommended for less experienced riders in poor grip conditions. The S map is a “full power” map, but with a softer throttle response. The T map is a “full power” map with extremely direct throttle response (recommended for expert riders).
*Please Note: Dealer installation is required, due to throttle and handle learning procedures that must be done with Aprilia Axone, Navigator, or PADs.
This is an electrical part. All electronic parts sales are final. Electronic parts are non-refundable, non-returnable.
這邊文章我有看過,所以公司給的ECU就是這顆嗎 what hero Smile
嚴格來說分兩種方式獲得,一種是跟aprilia racing 購買蠍子全段管
購買後會給予一組密碼,好利用診斷電腦下載map後灌進你的ECU內
這樣車上螢幕就會顯示有RACE字樣,即可獲得全馬力
第二種方式就是跟蠍子管原廠購買全段管,然後會附上一顆ECU,插上就好
但是還是需要有診斷電腦將電子油門跟節流閥歸零後,方可開始使用
kokobuster 寫到:
是喔!
我有核對過料號
今天有跟旗艦店的售後服務技師聊到
所謂的RACE ECU 是跟車上同樣的一顆ECU 裡面灌不一樣的軟體罷了 hero
(買管附的那顆裡面是空白的,需要拿它上面的序號去APRILIA總公司的官網裡面下載軟體才有辦法把RACE MAP載下來,放到新的ECU裡)
不過我一直以為RSV4沒有分地區 進來都是全馬力 what
我記得交車的時候單子上有寫,我算過沒有少阿 Surprised
都是全馬力,但R模前3檔有限制扭力,S模油門還可以亂轉,T模"重鹹"使用者限定。
kokobuster 寫到:
今天有跟旗艦店的售後服務技師聊到
應該是說race map對應的是沒有觸媒的直通改裝管,所以如果有改全段直通管,應該要連ECU一起改供油比較好。至於全馬力的話沒有聽過有閹割的情形
好像是 不管美規 歐規 公司貨 前代理商 進口的 全部都是全馬力
之前特價67的也都是全馬力嗎 what ?
都是全馬力
MAP調出來都一模一樣
買到賺到....顆顆
請問工廠版的一樣也有這顆電腦可以換嗎?
